eton
Nov 22, 2012Luminary
Factory reset - workaround idea with double set of disks
I've just go an idea. Is it possible to first remove the disks and install another set and then make a factory reset of the unit and after that put the old disks back? Will that work? Will th...
eton
Nov 23, 2012Luminary
Thanks
I pretty much knew that it wouldn't work. Otherwise this had been a known trick.
