eton
Nov 22, 2012Luminary
Factory reset - workaround idea with double set of disks
I've just go an idea. Is it possible to first remove the disks and install another set and then make a factory reset of the unit and after that put the old disks back? Will that work? Will th...
Nov 24, 2012Guru - Experienced User
This FAQ is about moving your disks from one NAS to another. This is a totally different case - there is no factory reset involved.
Digger2010 wrote: According to the attached link below suggests that it might work or is it a different case?
http://www.readynas.com/kb/faq/boot/how ... to_another
