eton
Nov 22, 2012Luminary
Factory reset - workaround idea with double set of disks
I've just go an idea. Is it possible to first remove the disks and install another set and then make a factory reset of the unit and after that put the old disks back? Will that work? Will th...
Digger2010
Nov 25, 2012Aspirant
Factory presets can only occur if the disk is mounted. Factory preset should only affect the new disks and old might still work?!
