eton
Nov 22, 2012Luminary
Factory reset - workaround idea with double set of disks
I've just go an idea. Is it possible to first remove the disks and install another set and then make a factory reset of the unit and after that put the old disks back? Will that work? Will th...
mdgm-ntgr
Nov 25, 2012NETGEAR Employee Retired
If you added old disks to an array then they'd need to be wiped. To make sure the old disks are wiped it would be best to hot-add (add while NAS is on) those disks.
