eton
Nov 22, 2012Luminary
Factory reset - workaround idea with double set of disks
I've just go an idea. Is it possible to first remove the disks and install another set and then make a factory reset of the unit and after that put the old disks back? Will that work? Will th...
Digger2010
Nov 25, 2012Aspirant
Example:
-Nas with a disk and everything works and is up to date.
-Turn off the nas and the remove the disk.
-Start NAS insert a new disk and preform factory default / reset.
The new disk is now operational and updated.
-Turn off the nas and the replace disk to the first and start Nas.
should not the first disk function now ( without being wiped) ?
