eton
Nov 22, 2012Luminary
Factory reset - workaround idea with double set of disks
I've just go an idea. Is it possible to first remove the disks and install another set and then make a factory reset of the unit and after that put the old disks back? Will that work? Will th...
mdgm-ntgr
Nov 25, 2012NETGEAR Employee Retired
You mean power off, remove all the new disks and put the old disk(s) back in, then power on.
Yes that should work. However SATA connectors are designed for a limited number of pulls and handling disks bare it is easy to damage them through ESD without realising it.
