rugene
Jun 02, 2016Guide
Failed to create snapshot...
For unknown reasons, I am randomly getting "Failed to create snapshot ...." on my shares. I have never seen this before. It could be related to an in-progress scrub process but I am not sure. Eventu...
StormCloud
Jun 07, 2016Aspirant
Yes. Getting since upgrading to 6.5. We are doing hourly snapshots. Will get the message once or twice in a row, and just had 3 in a row over the last 3 hours.
Subject is:
ReadyNAS Alert Message (NasName Miscellaneous: Warning)
Message is:
Failed to create snapshot c_xxxx for share or LUN 'xxxxxxx'.
BrianL2
Jun 09, 2016NETGEAR Employee Retired
Hi StormCloud,
Which model are you using? And do you mean that after scrubbing the volume, the snapshot went fine again? You can also send us the logs so we can have a look at your system.
Kind regards,
BrianL
NETGEAR Community Team
