devs1
Jun 16, 2012Aspirant
False SMART errors from bay on NAS Duo??
Hi all I've been puzzling over why I'm continually receiving smart errors from bay one on my nas duo. I've replaced the drive in bay one with 4 different brand new drives and also swapped the good ...
Jun 17, 2012Guru - Experienced User
No, that is not correct. The count is retained within the drive itself, so you should get the same stats reported on the PC as the Duo.
mdgm wrote: Once sectors are reallocated they're reallocated. A subsequent SMART check using a PC won't even notice the previously reallocated sectors, I think.
Read/write tests would pass of course (assuming all the bad sectors have been reallocated).
Can you try Acronis Disk Monitor? Here is a download link: http://www.acronis.com/homecomputing/do ... e-monitor/
If Acronis Disk Monitor also shows 0 reallocated sectors when you look at the stats, then that suggests that the NAS is somehow not reading the stats correctly - which is very strange. I agree that upgrading the firmware to the released version is a good idea. If you are still seeing reallocated sectors on the NAS but none on the PC after the upgrade, then you should open a support ticket.
