Pommes
May 29, 2017Aspirant
Fan is pulsing in OS 6.7.1 on my Ultra 2
Hi there, lately I updated my ultra2 to the latest firmware (6.7.4 - comming from 6.5.0), since then the fan is pulsing every some seconds. The fan goes within 1 sec from ~700 rpm to 1000 rpm an...
- May 31, 2017
I believe we have located the issue. There is a hardware chip that is tasked with controlling the fan speed, and we give it a target RPM. I believe the tolerance range is set too tight for some fans, and when they can't get close enough to the target it results in the pulsing action you described. Next firmware release will relax the tolerace which should resolve it.
cpu8088
May 29, 2017Virtuoso
select a different setting for fans
or dont sit near the nas.
Pommes
May 30, 2017Aspirant
1. fan settings have no influence on the pulsing.
2. Not an acceptable solution.
- StephenBMay 30, 2017Guru - Experienced User
If you enable ssh, you could also try this: https://community.netgear.com/t5/Using-your-ReadyNAS/OS-6-5-2-still-causes-fan-issues-on-the-PRO-6-like-OS-6-5-1-but/m-p/1138003/highlight/true#M115451
That would set the minimum fan speed to 1000 rpm.
This behavior is odd though, I am wondering if other people running OS 6.7.x on their ultra 2s are seeing it.
- PommesMay 30, 2017Aspirant
No, it doesn't help either.
It is still pulsing, but the range is smaller now. It pulses from ~950 to ~1050.
It's still annoying, because this pulsing happens in less than a second.
