Pommes
May 29, 2017Aspirant
Fan is pulsing in OS 6.7.1 on my Ultra 2
Hi there, lately I updated my ultra2 to the latest firmware (6.7.4 - comming from 6.5.0), since then the fan is pulsing every some seconds. The fan goes within 1 sec from ~700 rpm to 1000 rpm an...
- May 31, 2017
I believe we have located the issue. There is a hardware chip that is tasked with controlling the fan speed, and we give it a target RPM. I believe the tolerance range is set too tight for some fans, and when they can't get close enough to the target it results in the pulsing action you described. Next firmware release will relax the tolerace which should resolve it.
Pommes
May 30, 2017Aspirant
No, it doesn't help either.
It is still pulsing, but the range is smaller now. It pulses from ~950 to ~1050.
It's still annoying, because this pulsing happens in less than a second.
Skywalker
May 31, 2017NETGEAR Expert
- PommesJun 01, 2017Aspirant
Great, I'm looking forward for this release.
Best regards,
Patrick
