Brammeke
Apr 22, 2011Aspirant
Fan speed and system temperature via MRTG
Hi all I'm trying to use MRTG to graph the fan speed and system temperature. This is an excerpt of my mrtg.conf: Target[fan]: .1.3.6.1.4.1.4526.18.4.1.2&.1.3.6.1.4.1.4526.18.4.1.2:public@127.0....
Brammeke
Aug 26, 2011Aspirant
The configs... With these I can monitor about every aspect of the system, and even the influence of the sun on my garage. A similar configuration is possible on the ReadyNAS Duo. Don't know about other ReadyNAS devices.
mrtg.cfg
mrtg.cpu.cfg
mrtg.eth0.cfg
mrtg.fan.cfg
mrtg.hdd.cfg
mrtg.hddtemperature.cfg
mrtg.memory.cfg
mrtg.systemtemperature.cfg
mrtg.cfg
# Created by
# /usr/bin/cfgmaker --global 'WorkDir: /c/mrtg' --output /etc/mrtg.cfg public@127.0.0.1
### Global Config Options
# for Debian
WorkDir: /var/www/mrtg
### Global Defaults
PageTop[$]: <a href="index.html">Back to main page...</a>
WriteExpires: Yes
EnableIPv6: no
WorkDir: /c/mrtg
Include: mrtg/mrtg.eth0.cfg
Include: mrtg/mrtg.cpu.cfg
Include: mrtg/mrtg.memory.cfg
Include: mrtg/mrtg.hdd.cfg
Include: mrtg/mrtg.fan.cfg
Include: mrtg/mrtg.systemtemperature.cfg
Include: mrtg/mrtg.hddtemperature.cfg
mrtg.cpu.cfg
LoadMIBs: /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
Target[localhost.cpu]: ssCpuRawUser.0&ssCpuRawUser.0:public@127.0.0.1 + ssCpuRawSystem.0&ssCpuRawSystem.0:public@127.0.0.1 + ssCpuRawNice.0&ssCpuRawNice.0:public@127.0.0.1
MaxBytes[localhost.cpu]: 100
Title[localhost.cpu]: CPU Load
PageTop[localhost.cpu]: <h1>CPU Load</h1>
Unscaled[localhost.cpu]: ymwd
ShortLegend[localhost.cpu]: %
YLegend[localhost.cpu]: CPU Utilization
LegendI[localhost.cpu]: Active
Options[localhost.cpu]: noo, growright, gauge
mrtg.eth0.cfg
### Interface 2 >> Descr: 'eth0' | Name: 'eth0' | Ip: '10.0.0.72' | Eth: '00-0d-a2-02-77-3d' ###
Target[localhost.eth0]: 2:public@127.0.0.1:
SetEnv[localhost.eth0]: MRTG_INT_IP="10.0.0.72" MRTG_INT_DESCR="eth0"
MaxBytes[localhost.eth0]: 125000000
Title[localhost.eth0]: eth0 Traffic
PageTop[localhost.eth0]: <h1>eth0 Traffic</h1>
Options[localhost.eth0]: growright
mrtg.fan.cfg
#LoadMIBs: /usr/share/snmp/mibs/READYNAS-MIB.txt
Target[localhost.fan]: .1.3.6.1.4.1.4526.18.4.1.2.1&.1.3.6.1.4.1.4526.18.4.1.2.1:public@127.0.0.1
Options[localhost.fan]: gauge, nopercent, noo, growright
MaxBytes[localhost.fan]: 4000
Title[localhost.fan]: Fan Speed
PageTop[localhost.fan]: <H1>Fan Speed</H1>
YLegend[localhost.fan]: RPMS
ShortLegend[localhost.fan]: RPMS
LegendI[localhost.fan]: Rear Fan
WithPeak[localhost.fan]: ymwd
Unscaled[localhost.fan]: ymwd
Colours[localhost.fan]: SKYBLUE#87CEEB,PLUM#DDA0DD,STEELBLUE#FFA500,PURPLE#800080
mrtg.hdd.cfg
Target[localhost.hdd]: .1.3.6.1.4.1.4526.18.7.1.6.1&.1.3.6.1.4.1.4526.18.7.1.6.1:public@127.0.0.1
MaxBytes[localhost.hdd]: 3000000000
Title[localhost.hdd]: HDD Free Space
PageTop[localhost.hdd]: <h1>HDD Free Space</h1>
ShortLegend[localhost.hdd]:
YLegend[localhost.hdd]: Free Space
LegendI[localhost.hdd]: Free Space
Options[localhost.hdd]: gauge, growright, nopercent, noo
kMG[localhost.hdd]: M,G,T,P,X
Target[localhost.hdd1temperature]: ((.1.3.6.1.4.1.4526.18.3.1.5.1&.1.3.6.1.4.1.4526.18.3.1.5.1:public@127.0.0.1 - 32) * 5) / 9
Options[localhost.hdd1temperature]: gauge, nopercent, noo, growright
MaxBytes[localhost.hdd1temperature]: 64
Title[localhost.hdd1temperature]: hdd1 Temperature
PageTop[localhost.hdd1temperature]: <H1>hdd1 Temperature</H1>
YLegend[localhost.hdd1temperature]: Degrees Celcius
ShortLegend[localhost.hdd1temperature]: °C
LegendI[localhost.hdd1temperature]: hdd1
WithPeak[localhost.hdd1temperature]: ymwd
Unscaled[localhost.hdd1temperature]: ymwd
Colours[localhost.hdd1temperature]: GOLD#FFD700,RED#FF0000,ORANGE#FFA500,DARK RED#8B0000
Target[localhost.hdd2temperature]: ((.1.3.6.1.4.1.4526.18.3.1.5.2&.1.3.6.1.4.1.4526.18.3.1.5.2:public@127.0.0.1 - 32) * 5) / 9
Options[localhost.hdd2temperature]: gauge, nopercent, noo, growright
MaxBytes[localhost.hdd2temperature]: 64
Title[localhost.hdd2temperature]: hdd2 Temperature
PageTop[localhost.hdd2temperature]: <H1>hdd2 Temperature</H1>
YLegend[localhost.hdd2temperature]: Degrees Celcius
ShortLegend[localhost.hdd2temperature]: °C
LegendI[localhost.hdd2temperature]: hdd2
WithPeak[localhost.hdd2temperature]: ymwd
Unscaled[localhost.hdd2temperature]: ymwd
Colours[localhost.hdd2temperature]: GOLD#FFD700,RED#FF0000,ORANGE#FFA500,DARK RED#8B0000
Target[localhost.hdd3temperature]: ((.1.3.6.1.4.1.4526.18.3.1.5.3&.1.3.6.1.4.1.4526.18.3.1.5.3:public@127.0.0.1 - 32) * 5) / 9
Options[localhost.hdd3temperature]: gauge, nopercent, noo, growright
MaxBytes[localhost.hdd3temperature]: 64
Title[localhost.hdd3temperature]: hdd3 Temperature
PageTop[localhost.hdd3temperature]: <H1>hdd3 Temperature</H1>
YLegend[localhost.hdd3temperature]: Degrees Celcius
ShortLegend[localhost.hdd3temperature]: °C
LegendI[localhost.hdd3temperature]: hdd3
WithPeak[localhost.hdd3temperature]: ymwd
Unscaled[localhost.hdd3temperature]: ymwd
Colours[localhost.hdd3temperature]: GOLD#FFD700,RED#FF0000,ORANGE#FFA500,DARK RED#8B0000
Target[localhost.hdd4temperature]: ((.1.3.6.1.4.1.4526.18.3.1.5.4&.1.3.6.1.4.1.4526.18.3.1.5.4:public@127.0.0.1 - 32) * 5) / 9
Options[localhost.hdd4temperature]: gauge, nopercent, noo, growright
MaxBytes[localhost.hdd4temperature]: 64
Title[localhost.hdd4temperature]: hdd4 Temperature
PageTop[localhost.hdd4temperature]: <H1>hdd4 Temperature</H1>
YLegend[localhost.hdd4temperature]: Degrees Celcius
ShortLegend[localhost.hdd4temperature]: °C
LegendI[localhost.hdd4temperature]: hdd4
WithPeak[localhost.hdd4temperature]: ymwd
Unscaled[localhost.hdd4temperature]: ymwd
Colours[localhost.hdd4temperature]: GOLD#FFD700,RED#FF0000,ORANGE#FFA500,DARK RED#8B0000
mrtg.memory.cfg
Target[localhost.memory]: .1.3.6.1.4.1.2021.4.6.0&.1.3.6.1.4.1.2021.4.4.0:public@127.0.0.1
MaxBytes[localhost.memory]: 1000000
Title[localhost.memory]: Available Memory
PageTop[localhost.memory]: <h1>Available Memory</h1>
ShortLegend[localhost.memory]:
YLegend[localhost.memory]: Physical + Swap
LegendI[localhost.memory]: Physical
LegendO[localhost.memory]: Swap
Options[localhost.memory]: gauge, growright, nopercent
kMG[localhost.memory]: k,M,G,T,P,X
Target[localhost.systemperature]: ((.1.3.6.1.4.1.4526.18.5.1.2.1&.1.3.6.1.4.1.4526.18.5.1.2.1:public@127.0.0.1 - 32) * 5) / 9
Options[localhost.systemperature]: gauge, nopercent, noo, growright
MaxBytes[localhost.systemperature]: 64
Title[localhost.systemperature]: System Temperature
PageTop[localhost.systemperature]: <H1>System Temperature</H1>
YLegend[localhost.systemperature]: Degrees Celcius
ShortLegend[localhost.systemperature]: °C
LegendI[localhost.systemperature]: System
WithPeak[localhost.systemperature]: ymwd
Unscaled[localhost.systemperature]: ymwd
Colours[localhost.systemperature]: CRIMSON#DC143C,MAROON#800000,GREY#808080,DARK SLATE GREY#2F4F4F
