BeatCrazy
Jul 24, 2011Aspirant
Faster restore option: USB 2.0 or Gigabit E?
Hi, I have a regular NV, and was running a single 2TB HDD. That drive took a crap, and I need to restore with a brand new drive. I have about 700GB of FLAC files, and a couple of shares of odds a...
mdgm-ntgr
Jul 24, 2011NETGEAR Employee Retired
NTFS would probably be pretty slow. I'd seriously consider transferring the data across your network.
If you connect the USB disk to the NAS, you can do a Frontview backup job. You select the USB disk as the source and the share on the NAS as the destination. It's very straightforward.
If you want to backup a path on the USB drive you can type it in the path field e.g. "foldername1/foldername2" (no quotes)
