BeatCrazy
Jul 24, 2011Aspirant
Faster restore option: USB 2.0 or Gigabit E?
Hi, I have a regular NV, and was running a single 2TB HDD. That drive took a crap, and I need to restore with a brand new drive. I have about 700GB of FLAC files, and a couple of shares of odds a...
mdgm-ntgr
Jul 24, 2011NETGEAR Employee Retired
The config is stored on the disks. Unless you downloaded the config sometime before the NAS failed you will have to manually reconfigure the NAS from scratch.
I'd suggest putting a disk in the NAS, updating to the latest firmware (if not already running it), then do another factory reset to get a clean setup on the latest firmware. A factory reset after updating to 4.1.7+ will give you 4k sector alignment which is important with most 2TB disks.
I'd suggest having a couple of disks installed in your ReadyNAS. Disks can and do fail at any time and having a couple of disks installed running X-RAID or Flex-RAID RAID-1, reduces the likelihood of needing to do a full restore from backup.
