wquatan's avatar
wquatan
FF Browseable
What might be the reason that the setup-pages aren't browseable ?
I'm using FF 23.0.1 and especially for the System/Settings page this very annoying
Any solution ?
  • Now I See.
    Very confusing and not so user-friendly.
    One has to know there can be another kind of scrollbar under the Refresh button.
    I was expecting the "normal" (always visible) scrollbar.
    Would be better is it was always visible (when available on the page) and not just when the mouse gets moved there
    Thank you very much for your time !!
  • StephenB's avatar
    Personally I would rather see the scrollbars all the time - particular when using a touch interface.
    Even with a mouse, it is a hint that there is more to see.
  • Exactly what I was writing.
    I have been searching and searching to change the mail notification settings, and couldn't find it, because of that.
    As you said, I wasn't aware there was more on that settings-page.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Using some browsers (e.g. Safari on the iPad) I would find always visible scrollbars annoying. So I think if it was provided I would prefer it as an optional setting that could be turned off/on based on user preference.
  • StephenB's avatar
    I have no problem with an option. I actually want them always visible on the ipad - I don't want to have to go touching things trying to find them.
ProSupport for Business
