GGITech
Jul 30, 2015Apprentice
Firmware 6.2.5 Where is any information on Netgear?
So I login to my ReadyNAS and it notifies me that 6.2.5 is avaliable. After all the screwups that 6.2.2 created, I thought I'd at least read the release notes before I blind update a running device....
mdgm-ntgr
Jul 30, 2015NETGEAR Employee Retired
You can search for the product on support.netgear.com then click on Get More Downloads you will see the Release Notes. If you simply download the zip file you will also see that the Release Notes and the firmware image are contained in the zip file. This method can be used to get the latest firmware for all NETGEAR products.
If things are working fine for you on 6.2.4 then I wouldn't see an urgent need to upgrade.
Thanks for your feedback. We are working through how best to advise of new firmware releases on the forums.
GGITech
Thanks MDGM, you are the single person that has helped me in all cases.
Netgear as a company has been totally useless, and of course, after waiting 89 days to try to troubleshoot THEIR problem with 6.2.2 I was out of warranty when you got to fixing it.
God Bless you sir, Netgear is lucky to have you....if only their entire operation had the work ethic that you do.
I'll leave it at 6.2.4 for now.
