doujungle
Aug 16, 2016Aspirant
Firmware 6.5.1 - SMB down after reboot
Everything working fine until FW 6.5.1.
Once I upgraded to the above FW, my LG TV can see the NAS still but no changes I make to the nas show up.
I can see the NAS on OS X if I browse it, but am no longer able to map via AFP, CIFS, or SMB. Raidar sees the nas on OS X. (All windows machines see it fine). All file sharing permissions are still the same as before.
Anyone know of a fix for this issue? I've read that there is no rolling back FW from 6.5.x verisons.
Thank you
- mdgm-ntgrNETGEAR Employee Retired
Do you have a backup?
Can you send in your logs (see the Sending Logs link in my sig)?
- JohnRoNETGEAR Employee Retired
Hi doujungle,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- robrobinsonAspirant
I am having this same issue. Was there ever a resolution ??? This is holding up a lot of my researchers that are using windows.
Try this (as a test).
Open CMD
net use * /delete
net use t: \\nasipaddress\data /user:admin nasadminpassword
See if that mounts the data volume as drive letter t.
- doujungleAspirant
This did not work. Also, I don't see how that helps the TV see updated content on the NAS.
