rimmerhg
Jan 14, 2017Aspirant
Firmware 6.6.0 & 6.6.1 error in Diag report from Raidar
After Firmware 6.6.0 and 6.6.1 the text below is reported in the Diagnostics report from RAIDar Dated and timed at ever boot:- home.mount: Directory /home to mount over is not empty, mountin...
- Jan 16, 2017
We don't have an ETA yet. But those warnings can be safely ignored. If you'd prefer fixing it up from the command line, I can post instructions.
mdgm-ntgr
Jan 15, 2017NETGEAR Employee Retired
This means that at some point the /home mount point was not mounted but the system wrote some data under /home anyway so there's some data on the root volume that should be on the data volume.
Can you send in your logs (see the Sending Logs link in my sig)?
