JohnNulty
May 27, 2017Apprentice
Firmware Update 6.7.3 -> 6.7.4 OK
For the record, I have just updated 6.7.3 -> 6.7.4 and all is fine and well. I know a bit of positive reinforcement is always welcome from the devs and fellow users alike, especially in light of the...
Greg_M
May 27, 2017Aspirant
Hi everyone.
Just upgraded the firmware to 6.7.4 and was wondering how stable this version was, or if anyone is having the same issues I am experiencing?
- mediaservers (both Netgear and Nero MediaHome) are no longer working;
- the admin pages are noticably slower;
- cloud page under Admin fails to load and logs me out;
These are the things experienced so far.
Was wondering if anyone else was having the same issues?
Running RN104.
Greg
- mdgm-ntgrMay 27, 2017NETGEAR Employee Retired
Greg_M send in your logs (see the Sending Logs link in my sig).
- Greg_MMay 28, 2017Aspirant
Hello.
Just sent it to you now.
Thanks for looking into this for me.
Regards
Greg
- mdgm-ntgrMay 28, 2017NETGEAR Employee Retired
Greg_M the logs show that you updated from 6.6.1 to 6.7.4.
I can see your system was OOMing (running Out of Memory). This may suggest that you're running quite a bit on this system.
In meminfo.log I can seeSwapTotal: 523708 kB
SwapFree: 150352 kBSo you're using most of the swap space.
You could try disabling quotas on the data volume if you haven't already and see if this helps.
