bridges86406's avatar
May 25, 2017
Firmware update 6.7.3 Issue
Just installed the 6.7.3 firmware so that my device was protected from the Samba CSV.
Now I can't change the fan profile on the unit.
It allows me to go in and change from Quiet, Balanced, Cool, as it did before.  However now when I make a change, the fans don't change at all.
They are currently spinning at 6700 RPM.  Which is fine after 6-7pm but since I'm trying to work in my office today is not going to work.
I have a ReadyNas 3138, with two 4TB Western Digital Reds.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello bridges86406,
    Have you tried rebooting after changing the fan setting? By the way, are there apps running at the same time?
    • Yes I have tried restarting. Fan setting is unchanged.
      One app is running.......Plex, with 0 users.  The CPU and System are under 100* F, so it's not a heat issue and I have not had this issue with the fans since getting the unit in December.  I change it very regularly as needed.
      • JennC's avatar
        JennC
        Hello bridges86406,
        Can you check if you get the same problem when disable Plex? If you have AntiVirus, see if sasme results when it is also disable.
  • Just did, hoping this would fix the issue; it did not.
    Upgrading to 6.7.4 did NOT fix the issue.
    • mdgm-ntgr's avatar
      mdgm-ntgr
      Can you send in your logs (see the Sending Logs link in my sig)? If you can't download them using the GUI try downloading them using RAIDar.
  • evan2's avatar
    evan2
    NETGEAR Expert
    I reproduced the issue on my RN3130,
    Thanks for your report.
ProSupport for Business
