bridges86406
May 25, 2017Tutor
Firmware update 6.7.3 Issue
Just installed the 6.7.3 firmware so that my device was protected from the Samba CSV. Now I can't change the fan profile on the unit. It allows me to go in and change from Quiet, Balanced, Cool, ...
- May 31, 2017
This is a issue on RN3130/3138 with 6.7.3 and 6.7.4 installed,
and has been fixed on internal T building,
evan2
May 27, 2017NETGEAR Expert
I reproduced the issue on my RN3130,
Thanks for your report.
bridges86406
May 31, 2017Tutor
Looks like there has been no resolution as of yet?
I sent logs within an hour of the request.
- evan2May 31, 2017NETGEAR Expert
- bridges86406Jun 01, 2017Tutor
The T build, does indeed stop the fans from screaming along at 6900 RPM. However, it still appears as though the fan "profiles" still do not work. So moving between Quiet, Balanced, Cool have no affect on fan speed.
Ignore my previous statement on the profiles. They do indeed work, just slower than they previously worked when the profile was changed.
