bridges86406
May 25, 2017Tutor
Firmware update 6.7.3 Issue
Just installed the 6.7.3 firmware so that my device was protected from the Samba CSV. Now I can't change the fan profile on the unit. It allows me to go in and change from Quiet, Balanced, Cool, ...
- May 31, 2017
This is a issue on RN3130/3138 with 6.7.3 and 6.7.4 installed,
and has been fixed on internal T building,
bridges86406
May 26, 2017Tutor
Just did, hoping this would fix the issue; it did not.
Upgrading to 6.7.4 did NOT fix the issue.
mdgm-ntgr
May 26, 2017NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)? If you can't download them using the GUI try downloading them using RAIDar.
