bridges86406
May 25, 2017Tutor
Firmware update 6.7.3 Issue
Just installed the 6.7.3 firmware so that my device was protected from the Samba CSV. Now I can't change the fan profile on the unit. It allows me to go in and change from Quiet, Balanced, Cool, ...
- May 31, 2017
This is a issue on RN3130/3138 with 6.7.3 and 6.7.4 installed,
and has been fixed on internal T building,
bridges86406
May 25, 2017Tutor
Yes I have tried restarting. Fan setting is unchanged.
One app is running.......Plex, with 0 users. The CPU and System are under 100* F, so it's not a heat issue and I have not had this issue with the fans since getting the unit in December. I change it very regularly as needed.
JennC
May 25, 2017NETGEAR Employee Retired
Hello bridges86406,
Can you check if you get the same problem when disable Plex? If you have AntiVirus, see if sasme results when it is also disable.
- bridges86406May 25, 2017Tutor
I don't use the Anti-virus.
I disabled Plex - No Change.
I then rebooted (with Plex still disabled) - No Change.
- mdgm-ntgrMay 26, 2017NETGEAR Employee Retired
If you have updated to 6.7.3 and ran into this issue please update to ReadyNAS OS 6.7.4 which is now available! You might need to do this using USB Boot Recovery.
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
