bbh03's avatar
bbh03
Firmware upgrade for NV
Hello,
I am trying to upgrade my ReadyNAS NV (original, not NVX, NV+, etc) with P/N RNV1-S2-0000 and Serial 000D-A201-14CC, but cannot find support for this specific model (documentation or manuals, etc). I would like to do this before upgrading to larger disks (currently running two 500GB disks with RAIDiator™ v3.00c1-p2 [1.00a025]. Any help would be appreciated! Also, what is the largest size disk supported once firmware is up to date?
Thanks
Brian
  • The NV can use the same disks as the NV+. So you can reference the NV+ Disk HCL.
    The current firmware is 4.1.10. Max disk size is 2TB.
  • Thank you! I located the software but when trying to upgrade on the local tab, the "upload and verify image" remains greyed out although the firmware image file is selected. Any ideas? The remote tab cannot locate the server which is why I am trying manually.
  • Was using safari (all macs here). I tried Firefox and same problem. No ie for Mac so do I need to borrow someone's pc?
  • Downloaded Opera and was successful. Thanks for your help!
ProSupport for Business
