HendeV
Feb 02, 2017Aspirant
Firmware upgrade using SSH OS6
I am running a ReadyNAS 300 using firmware 6.2.2 and I'm not able to access the webinterface (http://IP_of_NAS/admin). Appearently this was a known issue and this should be solved in newer firmware ...
HendeV
Since # systemctl status apache2 did not show a broken symlink I will install the new firmware. I need to do this after working hours.
Thank you for your quick reply!
mdgm-ntgr
Feb 02, 2017NETGEAR Employee Retired
Oops.
There would be information in the output of
# journalctl
The broken symlink would be in /etc/apache2/sites-enabled if I recall correctly.
