jumax
Jul 01, 2010Aspirant
Folder Access Issue
I have a couple of folders on my readynas share that I can't seem to access they have a little white dash in a red circle on them, when i do getinfo on them it says I have read and write permission, ...
Yacht_Rocked
Jul 07, 2010Aspirant
sphardy wrote:
You mention using AFP & CIFS - it's usually best to stick to just one protocol. Running into permissions problems is common when using multiple protocols as often the settings for each can be different. If you have Windows machines that will be accessing the NAS, stick with CIFs. If only Macs, then CIFS or AFP.
Great tip! I was having trouble accessing a couple of shares from my Mac, while accessing the others over AFP. I dropped all the connections and re-connected using CIFS (SMB://192.168.x.x/<sharename>) and that has solved this Mac issue. Thanks!
