Headlamps
Jun 05, 2012Aspirant
Format a drive inside the NASBox
Hi - I have looked through available documentation and this forum. Sorry if I've missed the answer somewhere. I have a ReadyNAS DUO (RND2110-100NAS) with two1TB Seagate Barracudas installed. One of...
mdgm-ntgr
Jun 05, 2012NETGEAR Employee Retired
Though not recommended you could do this:
1. Power down NAS
2. Carefully remove good disk
3. Do a factory default (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu). Note that this will wipe all disks in the NAS at the time it is performed.
4. Power down and remove bad disk
5. Carefully put good disk back in same slot as before
6. Power NAS on.
1. Power down NAS
6. Power NAS on.
