Headlamps
Jun 05, 2012Aspirant
Format a drive inside the NASBox
Hi - I have looked through available documentation and this forum. Sorry if I've missed the answer somewhere. I have a ReadyNAS DUO (RND2110-100NAS) with two1TB Seagate Barracudas installed. One of...
ReadySECURE
Jun 06, 2012Apprentice
a factory default on a Duo with a single 1TB drive shouldn't take as long as you are seeing. The Boot Menu has you hold the reset for 30 seconds to get a factory default. It is sounding like it is running a memory test. I would suggest trying the Factory Default one more time.
