Headlamps
Jun 05, 2012Aspirant
Format a drive inside the NASBox
Hi - I have looked through available documentation and this forum. Sorry if I've missed the answer somewhere. I have a ReadyNAS DUO (RND2110-100NAS) with two1TB Seagate Barracudas installed. One of...
Headlamps
Jun 06, 2012Aspirant
The only other option (from Seagate) was to plug it into another pc - which would be difficult with the equipment I currently have: an old Alpha box from my DEC days and an old version of Redhat running on a Pentium III. I think I'll make sure all is well with the 2 good drives and then futz around with this reset thing again.
By the way, in the table you pointed me to - the one that has the 30 second time requirement for the Factory Default process - what is the "LED flashes" column supposed to be telling me? What leds are supposed to be flashing 2 times? All I get are all 4 green leds flashing (as well as the power light). I never see anything flash only twice.
What am I supposed to see if the Factory Defaults process actually runs? Is there some indication of success?
Also, how badly can I screw things up if I accidentially get into the "OS Re-install" process?
Muchos gracias senor...
