Headlamps
Jun 05, 2012Aspirant
Format a drive inside the NASBox
Hi - I have looked through available documentation and this forum. Sorry if I've missed the answer somewhere. I have a ReadyNAS DUO (RND2110-100NAS) with two1TB Seagate Barracudas installed. One of...
Headlamps
Jun 07, 2012Aspirant
Hi MDGM,
I appreciate all you tried to do with my problem. Unfortunately we couldn't get the Factory Default process to work - that takes away nothing from your efforts, thanks.
I have tried a few more times without success.
I was feeling pressed for time because I need to return the bad drive to Seagate tomarrow or they will charge me for the drive - argh! So I googled for someone local to reformat the drive for me. I cost $40.00 but at least I'm not sending Seagate a drive with all my banking formation on it!!
Now I just need to make plans to resolve this myself, should it ever happen again - or should I say, when it happens again...
Again, thanks for your help... problem solved.
Regards, Headlamps
Regards, Headlamps
