Stevenup
Jan 05, 2021Guide
Front view does not load any more
Hi guys, after my NAS cashed recently i managed to restart it - via OS reninstall follwoing the step by step in the user manual. Now the ready nas has finisched the data check and i can access al...
Stevenup
Jan 06, 2021Guide
Hi StephenB,
thank you soo much for your help and support. I hvae managed to follow your instructions and connect via Telnet to my NAs. i then used the code you provided and to the follwoing information back.
root@24M39C7S0028C:/# df // -h
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 2.0G 6.6M 100% /
root@24M39C7S0028C:/# df // -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/hdc1 128000 14356 113644 12% /
also see - attached print screen.
however, i am not sure how to interprete the above - is this confirming the OS partition is full (100%) - if so, where to from here?
if you could guid me with future code - or advise future steps - much appreciatd
thanks steven .
- StephenBJan 07, 2021Guru - Experienced User
Yes, this confims that the OS partition is full (only 6.6M left).
The next step is to figure out where the space is going (and why).
- Do you have any add-ons installed?
- Do you use ReadyDLNA?
ReadyDLNA by default put its cache in the OS partition, but there is an add-on that will move that to the C volume.
Another possibility is that the logs are simply too big. So also try
# df /var/log -h
and post that info here.
- StevenupJan 08, 2021Guide
Hi StephenB,
thank you,
I have entered the code you provided and got this:
I did not us DLNA or any other apps in my configuration while in use.
however - did after the crash do a USB boot verson 4.1.16 and a OS reinstall.
So i dont know if any of the above apps or ReadyDLNA would be activated by default.
I would also have to check both hard drives for errors/fault. I am not 100% sure even though they are less then two years old HD.
thank you for your future advise on how the clear the catch and any other suggestoins on finxing this issue.
Steven
Here again the screen shot as it has not worked in the previous post.
