freenode
Aug 22, 2015Aspirant
Frontview not accessible ReadyNAS RN102
Uninstalled some apps and Frontview will not load. Re-installed OS, no fix, Factory Reset, no fix, Upgraded firmware to 6.2.5 , no fix. Lost SSH when I did the Factory Reset. Any solutions availab...
Aug 23, 2015Guru - Experienced User
vandermerwe wrote:
Can you factory reset the nas with a single disk, that you know is good, in the nas.
Just to amplify this...
A factory reset should have solved your problem. I am puzzled on how you upgraded to 6.2.5 w/o frontview and ssh.
Perhaps some more information would be useful.
freenode
Aug 23, 2015Aspirant
StephenB wrote:
vandermerwe wrote:Can you factory reset the nas with a single disk, that you know is good, in the nas.
I upgraded to 6.2.5 through https://readycloud.netgear.com/ . I can see the NAS and access the folders through readycloud. but no Admin access.
I can factory reset the NAS with a known good disk, but it will be one that is already in the NAS. I have no other available "scratch" disk.
Not sure what a "scratch" disk is. I only have two disks. both disks inserted are known good, with no personal data. i.e. have been reformated, wiped clean.
When you say Frontview will not load, what happens when you run raidar? Does raidar see the nas?
Yes Raidar sees the NAS and reports
Model: ReadyNAS 102
Namae: xxxxReadyNAS
Serial: XXXXXXXXXX
Status: Healthy
Firmware: 6.2.5
IP Address: 192.168.1.101 (MAC)
Drives : Drive is operating normally; Drive is operating normally
What happens when you use raidar to access the admin pages?
Raidar Admin button pops open the browser and links to http://192.168.1.101 which re-directs to https://192.168.1.101/admin
resulting in https://192.168.1.101/admin connecting..... ERR_CONNECTION_TIMED_OUT
Mostly the page times out. Sometimes I get prompted to enter login username and password, then the page times out.
And rarely I get the front page of Frontview that shows Netgear ReadyNAS Version 6.2.5 and that is it.... nothing else .... the page stops loading as if it is complete.
What browser are you using? Chrome, Firefox, and as a last resort used Explorer
Have you cleared the browser cache and tried again? Yes, with each browser
- freenodeAug 23, 2015Aspirant
Correction:
"Your NETGEAR Storage is not accessible from this computer, please check your network settings" . So I have checked all my network settings and firewall settings on the computers, no sure what this is in reference to.The following is from owncloud.netgear.com Admin Page link ..
Admin Link button pops open the browser and links to http://192.168.1.101 which re-directs tohttps://192.168.1.101/admin
resulting in https://192.168.1.101/admin connecting..... ERR_CONNECTION_TIMED_OUTMostly the page times out. Sometimes I get prompted to enter login username and password, then the page times out.
