freenode
Aug 22, 2015Aspirant
Frontview not accessible ReadyNAS RN102
Uninstalled some apps and Frontview will not load. Re-installed OS, no fix, Factory Reset, no fix, Upgraded firmware to 6.2.5 , no fix. Lost SSH when I did the Factory Reset. Any solutions availab...
dspj
Aug 26, 2015Aspirant
I'm experiencing exactly the same problem as above, but with a RN312.
Admin startpage (or pre-page with the logo and version number) then a long try to reconnect, the time-out.
If those PM's from moderators help, i'd like to have one too!
dspj
To correct the "nothing happens":
I have occasionally seen the normal start screen for a split second (once even 3-4 seconds) before the "Connecting to ReadyNAS Admin Page..."-progress bar occurs. (so there must be some kind of connection).
