freenode
Aug 22, 2015Aspirant
Frontview not accessible ReadyNAS RN102
Uninstalled some apps and Frontview will not load. Re-installed OS, no fix, Factory Reset, no fix, Upgraded firmware to 6.2.5 , no fix. Lost SSH when I did the Factory Reset. Any solutions availab...
freenode
Aug 27, 2015Aspirant
Still haven't found the cause however mgdm suggested try connecting via hardwire ethernet port since all devices I was using was on wifi. I connected a pc via rj45 on the router, and sure enough I can access the frontview admin page. my issue seems to be related to wifi.
work around: connect via RJ45 port and not use wifi for access to frontview admin page.
