NASguru
Apr 13, 2017Apprentice
Frontview not accessible ReadyNAS Ultra4 Plus
I noticed today that I'm unable to login to my Ultra 4 Plus via Frontview. I can however see all the files using SMB. It's running OS 6.6.1 and I'm able to download the logs using RAIDar if that he...
mdgm-ntgr
Apr 13, 2017NETGEAR Employee Retired
Send in the logs (see the Sending Logs link in my sig)?
NASguru
Apr 14, 2017Apprentice
mdgm wrote:Send in the logs (see the Sending Logs link in my sig)?
MDGM, the logs have been sent. Thanks for taking the time out to look it over.
- NASguruApr 17, 2017Apprentice
mdgm-ntgr Any updates? I sent the logs last week and curious if anything stood out.
- mdgm-ntgrApr 17, 2017NETGEAR Employee Retired
The logs you sent were incomplete. I need the journal logs to fully diagnose this.
You could try updating to 6.7.1 Beta using https://ip.address.of.nas/fwbroker and see if this helps.- NASguruApr 18, 2017Apprentice
mdgm wrote:The logs you sent were incomplete. I need the journal logs to fully diagnose this.
You could try updating to 6.7.1 Beta using https://ip.address.of.nas/fwbroker and see if this helps.I sort of figured you would say that, but unfortunately the only logs I can grab are those offered through RAIDar. It makes me wonder what use those logs are if they are incomplete. That said, I looked at the FW update URL you posted from other links and willing to give it a whirl but don't have 6.7.1.beta available to me. Or at least, it's not shown as an option when I enter the link. However, there is a local update possible if I could download 6.7.1 beta seperately. See screen shot below. Thoughts?
