NASguru
Apr 13, 2017Apprentice
Frontview not accessible ReadyNAS Ultra4 Plus
I noticed today that I'm unable to login to my Ultra 4 Plus via Frontview. I can however see all the files using SMB. It's running OS 6.6.1 and I'm able to download the logs using RAIDar if that he...
NASguru
Apr 14, 2017Apprentice
mdgm wrote:Send in the logs (see the Sending Logs link in my sig)?
MDGM, the logs have been sent. Thanks for taking the time out to look it over.
NASguru
Apr 17, 2017Apprentice
mdgm-ntgr Any updates? I sent the logs last week and curious if anything stood out.
- mdgm-ntgrApr 17, 2017NETGEAR Employee Retired
The logs you sent were incomplete. I need the journal logs to fully diagnose this.
You could try updating to 6.7.1 Beta using https://ip.address.of.nas/fwbroker and see if this helps.- NASguruApr 18, 2017Apprentice
mdgm wrote:The logs you sent were incomplete. I need the journal logs to fully diagnose this.
You could try updating to 6.7.1 Beta using https://ip.address.of.nas/fwbroker and see if this helps.I sort of figured you would say that, but unfortunately the only logs I can grab are those offered through RAIDar. It makes me wonder what use those logs are if they are incomplete. That said, I looked at the FW update URL you posted from other links and willing to give it a whirl but don't have 6.7.1.beta available to me. Or at least, it's not shown as an option when I enter the link. However, there is a local update possible if I could download 6.7.1 beta seperately. See screen shot below. Thoughts?
- NASguruApr 21, 2017Apprentice
mdgm-ntgr Ok, it's been a busy week so I'm finally circling back to this post of mine. I was able to download and attempt installing 6.7.1 beta via the fwbroker link but unfortunatley it gave an error of:
ERROR 6001010101
file is missing or corrupt
So I didn't want to push my luck and ultimately decided to just use the Remote Update radio button and re-install 6.6.1. So far, I'm able to access my Ultra4+ via Front View/GUI again. I'll download the logs from there and resend them if that helps? Please advise when you get a chance. Thanks again!
