ReadyNasMan123
Oct 15, 2010Aspirant
fsck has taken 6 days so far
Following an abrupt power-off (powercord was unplugged), my ReadyNas NV has been busy doing an fsck for the past 6 days. I'm able to monitor progress by ssh into the box and looking at /var/log/front...
mdgm-ntgr
Oct 15, 2010NETGEAR Employee Retired
Sounds like something is wrong. The filesystem check should take hours at most, not days.
Edit: see post below. Best to let it finish.
If not, you might wish to follow the advice here: http://www.readynas.com/forum/faq.php#How_can_I_skip_the_Volume_check%3F
Be sure to download your logs.
Welcome to the forum!
