kamil1
Dec 30, 2014Aspirant
FTP Connecion and Problem "Acces denied"
Hello Friends, NAS duo v2 5.3.11 the ftp Service ist running on NAS, Authentication Mode ist "user" My router hat Static external IP, I set forwarding port 21 to NAS IP adres (it works !!!). ...
Dec 30, 2014Guru - Experienced User
Some things to check
(a) The FTP server should be set to passive mode, and you should adjust the port range to just a few ports (4-10). Ports over 50000 are good choices, as they are unassigned.
(b) The passive ports you choose also need to be forwarded to the NAS
(c) some clients will require masquerading to be set on the server to the external IP address of the router. Some don't need this (FileZilla doesn't). I don't know about total commander.
