Anonymous
Aug 28, 2016FTP 'Home Folder' Directory access for all?
I've recently factory reset a RN316 on OS 6.5.1 and I've enabled FTP access on OS 6.5.1 using this with Authentication Mode as 'user', however it does not set location of the FTP user home folder cor...
Anonymous
Aug 30, 2016Is there any documentation on the way Netgear ReadyNAS OS 6.5.1 FTP works?
I wanted to clarify, specifically, of FTPS = FTP via SSL-TLS?
I also wanted to clarify if that is different to SFTP?
I've found the following circumstances, and just wanted some clarity on it:
1) on the NAS-FrontView, I've enabled FTP with 'Enabled Forced FTPS'
2) I've enabled FTP access on the Home Folders
3) I then use Filezilla, with a non admin username and it logs in correctly to the correct folder, working fine, etc.
Status: Connection established, waiting for welcome message...
Status: Initializing TLS...
Status: Verifying certificate...
Status: TLS connection established.
Status: Logged in
Status: Retrieving directory listing...
Status: Directory listing of "/" successful
...and for user account SSH enabled:
Status: Logged in
Status: Server sent passive reply with unroutable address. Using server address instead.
(note: idk where the welcome.msg file should be stored for the NAS, the default proftpd locations don't work :()
4) Using Filezilla with the admin account works fine too - it logs into /home/admin/
5) But then, I then try to mount a share on a client machine using a SFTP mount point, the non-admin username fails and admin username accesses the whole NAS like root access (/)....
6) I enable SSH -> 'allow shell access' on each user account, and the client machine SFTP mount point works fine per user account and in the correct /home/ folder....and I beleive admin SFTP also mounts to /home/admin/
I'm a little confused - FileZilla uses TLS to access the correct home folder without enabling SSH on the user account on the NAS, yet mouting the share on a client machine using SFTP doesn't work until I enable SSH on the user account....admin works either way except it accesses as root via SFTP mount on the client machine...unless I enable SSH on a user account, then admin works like a normal user account (ie /home/admin/ is accessed).
Anonymous
Aug 30, 2016I've just used a SFTP mounting program (DirectNet Drive) on windows PC and, if the NAS has SSH enabled on a normal user account (with SSH enabled service), and FTP enabled it gives an error when trying to connect, however Filezilla still has access to the users's home folder..using TLS.
But when enabling FTP access on the Home Shares, the user has access to the root (/) folder....
using sftp://<username>:<password>@<ip>:22/
I beleive this is a major security flaw via OS 6.5.1 Frontview how it configures ProFTPD when FTP is enabled and SSH access is enabled for a normal (non-admin) user. It should restrict folder access based on the users home folder only and not allow any user access to root folder (/) ....root user being the exception (since console access is always logged in as root, so admin username should also be restricted to their home folder).
