tnorton00
Jan 05, 2018Guide
FTP Issue with Filezilla/WinSCP
Recently updated to firmware 9.6.1. Since then I've had an odd issue where users internally and externally get the attached image when using WinSCP or Filezilla. When using CoreFTP or Windows there...
tnorton00
Jan 05, 2018Guide
For reference I'm having the same issue as this user, sadly no resolution in that post. https://community.netgear.com/t5/Using-your-ReadyNAS/RN212-ftps-issues-after-6-8-0-firmware-update/m-p/1363728#M135861
Marc_V
Jan 11, 2018NETGEAR Employee Retired
Hi tnorton00
This issue has been investigated and points out to FTP Clients using MSLD command in order to retrieve file/folder list getting the issue when the primary group name of the domain user uses space e.g "Domain Users". In this case, Filezilla and WinSCP use MSLD command. I have no list of FTP Clients using MSLD or LIST though.
So the issue is actually related to Client FTPs not being able to handle domain user primary group name that has space included. The workaround is to use a different FTP client which uses LIST command to retrieve file/folder information or change the primary group name with no space included. but on another post, it seems that ARM-based models are getting the issue.
Hope this helps!
Regards
