stgeorge
May 04, 2017Guide
ftp refusing connections
Hey all- I'm curious what the most typical reason is for the standard ftp server loaded on these nas devices to 'refuse connections' ? Here's the messaging that I'm getting via a filezilla cl...
stgeorge
May 05, 2017Guide
I actually have had masquerading set on the NAS- that wasn't the issue- the issue was that the passive port range (in the ftp server's settings) was not the same range as that which I had forwarded in our router. It sounds pretty stupid of me, I'm sure, but the experience that I've found in the past (aka earlier versions of FileZilla) was that I didn't need to forward passive ports at all. In fact, if I remove the port forwarding instruction in my router for the passive port range, many ftp clients will work fine, and FileZilla used to, but this current version will not. Once I forwarded the same passive port range as was in the ftp server's settings, FileZilla works beautifully.
May 05, 2017Guru - Experienced User
It the port isn't forwarded by the router, the connection can't be made. The client behavior doesn't matter, there is no workaround that it can use.
Alternative explanation: Your old FTP server was using upnp to open the passive ports in your router.
The status message in the first post says that either masquerading is mis-configured or it is not enabled. That might have changed after that post was made. So perhaps double-check that setting.
