ventrj
Jul 27, 2011Aspirant
FTP Setup - Masqurade As) help
I have a ReadyNas duo and am trying to set up the FTP service. I have created a DNS entry with DYNDNSservice, and I have set up my Linksys router to forward port 21 to my NAS IP address. I am having...
ReadySECURE
Jul 30, 2011Apprentice
Yes, if you used your public external IP you would have to change that every time your IP changes. You always want to make sure you up to date on your firmware. The latest being 4.1.7 for older spac based units and 4.2.18 for the x86 units. Is there anything particular about your DNS name? Was the setup working up until the DNS name expired? Use canyouseeme.org to verify if the port is open. It sounds like it is configured correctly. You may want to open a support ticket if you are on the latest firmware.
Support Resources
Forums:
Prosafe: http://forum1.netgear.com
ReadyNAS: http://www.readynas.com/forum
Prosecure: http://prosecure.netgear.com/community/forum.php
Contact support or register a device
1-888-NETGEAR (638 - 4327) Option 4 for technical support
http://my.netgear.com
Knowledge base
http://support.netgear.com
Support Resources
Forums:
Knowledge base
