woto
Dec 19, 2017Aspirant
Ghost files - Re-scan scheduling
Hey Guys I read a post on here about ghost files that a TV can see using DLNA, that you have to rescan to get rid of them. So my question is there a way of of scheduling a rescan on the DLNA ...
bedlam1
Dec 19, 2017Prodigy
The ReadyNAS DLNA system has a default scan time of 900 seconds (every 15 minutes), this can be changed using SSH and say, putty, at /etc/minidlna.conf you can also change the "friendly" name of your DLNA server.
woto
thanks for the info,
this seems strange as its over 15mins that i have checked, i had a look at it lastnight and again thismorning and they where still there
- StephenBDec 19, 2017Guru - Experienced User
The auto scan is likely better at adding new files than it is at removing deleted files.
One possibility is to be able to set up a schedule for a full rescan. That would be a new feature, so maybe post it to the idea exchange.
- wotoDec 20, 2017Aspirant
i did a manual rescan on the DLNA, i found it got rid of the deleted files but i have noticed that one of my folders is missing, i checked it again after a hour or so but its still not there, might do a rescan again see if appears after that.
Does anyone know if Twonky can be installed on the ReadyNas i used to use that on my pc before i got a NAS and that seemed to work really well streaming direct to the TVs
- bedlam1Dec 20, 2017Prodigy
Have a look at "Apps" then "Available Apps" on your NAS GUI, "Twonky Server" should be there, but I have never used it personally
