woto
Dec 19, 2017Aspirant
Ghost files - Re-scan scheduling
Hey Guys I read a post on here about ghost files that a TV can see using DLNA, that you have to rescan to get rid of them. So my question is there a way of of scheduling a rescan on the DLNA ...
woto
Dec 20, 2017Aspirant
i did a manual rescan on the DLNA, i found it got rid of the deleted files but i have noticed that one of my folders is missing, i checked it again after a hour or so but its still not there, might do a rescan again see if appears after that.
Does anyone know if Twonky can be installed on the ReadyNas i used to use that on my pc before i got a NAS and that seemed to work really well streaming direct to the TVs
bedlam1
Dec 20, 2017Prodigy
Have a look at "Apps" then "Available Apps" on your NAS GUI, "Twonky Server" should be there, but I have never used it personally
- wotoDec 20, 2017Aspirant
i did look in the apps GUI, but i didn't see it there, i presumed that it had to be installed manually
- bedlam1Dec 20, 2017Prodigy
Oh OK, it is there for X86 processors (which I have) but you have ARM, sorry cannot advise you further then
- StephenBDec 20, 2017Guru - Experienced User
The other option for OS-6 NAS is plex - which also includes a DLNA server. You download it from plex and manually install it.
It's possible that your issue is due to a corrupt media file that is crashing the scan. Try downloading the log zip file from the web ui, and looking in upnp-av.log.
