mattbodman
Dec 16, 2019Tutor
Gmail oAuth does not work properly
I've just updated to 6.10.2 which contained an update to the email alert configuration to include support for Gmail oAuth. When trying to set this up, however, the form will not submit because the S...
mattbodman
Dec 17, 2019Tutor
Hi Marc, thanks for the reply. You'll notice by my screenshot that the form is partially populated. This happened after the oAuth pop-up, so the browser did not block anything. You can see that the user, password and from fields have been populated, but the SMTP server field is not populated. The result is the same with both Chrome and Safari. Regars
Marc_V
Dec 17, 2019NETGEAR Employee Retired
Hmmn, have you tried clearing the entries and then re-login/re-authenticate your google account? I have a RN528X and I did not see that when I tried logging in my account. It was populated automatically.
Perhaps try clearing your web browser before trying again. If the issue is still there, kindly send the logs thru Google drive.
Regards
