mads0100
Jan 18, 2015Guide
Gracefully restart RN104?
Hey guys, Are we allowed to post instructions for gracefully shutting down your RN via SSH on here? From what I can tell my Frontview GUI has stopped responding (6.2.2) and I just want to gracefu...
mads0100
Jan 24, 2015Guide
Attached is the data you requested. It happened again a few days later... same issue as far as I can tell.
apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled)
Active: active (running) since Sun, 18 Jan 2015 19:59:30 -0700; 6 days ago
Process: 1695 ExecReload=/bin/kill -USR1 $MAINPID (code=exited, status=0/SUCCESS)
Process: 1689 ExecReload=/usr/sbin/apache2 $OPTIONS -t (code=exited, status=0/SUCCESS)
Main PID: 1485 (apache2)
CGroup: name=systemd:/system/apache2.service
├ 1485 /usr/sbin/apache2 -k start
├ 1758 apache_log
├ 1762 apache_log
├ 1902 /usr/sbin/apache2 -k start
├ 1903 /usr/sbin/apache2 -k start
├ 1904 /usr/sbin/apache2 -k start
├ 1905 /usr/sbin/apache2 -k start
├ 1906 /usr/sbin/apache2 -k start
├ 1928 /usr/sbin/apache2 -k start
├ 2201 /usr/sbin/apache2 -k start
├ 2249 /usr/sbin/apache2 -k start
├ 3002 /usr/sbin/apache2 -k start
├ 3124 /usr/sbin/apache2 -k start
└ 14246 /usr/sbin/apache2 -k start
Jan 24 21:06:27 READYNAS apache2[14246]: [error] [client 192.168.1.126] Prem.../
Jan 24 21:06:27 READYNAS apache2[1905]: [error] [client 192.168.1.126] Conne.../
Jan 24 21:06:27 READYNAS apache2[1905]: [error] [client 192.168.1.126] Prema.../
Jan 24 21:06:41 READYNAS apache_access[1762]: Suppressed 4 duplicate messages
Jan 24 21:06:41 READYNAS apache_access[1762]: 192.168.1.126 "POST /dbbroker ...1
Jan 24 21:06:41 READYNAS apache2[1903]: [error] [client 192.168.1.126] Conne.../
Jan 24 21:06:41 READYNAS apache2[1903]: [error] [client 192.168.1.126] Prema.../
Jan 24 21:06:41 READYNAS apache_access[1762]: 192.168.1.126 "POST /dbbroker ...0
Jan 24 21:06:46 READYNAS apache2[3124]: [error] [client 192.168.1.126] Conne.../
Jan 24 21:06:46 READYNAS apache2[3124]: [error] [client 192.168.1.126] Prema.../
readynasd.service - ReadyNAS System Daemon
Loaded: loaded (/lib/systemd/system/readynasd.service; enabled)
Active: inactive (dead) since Wed, 21 Jan 2015 12:11:39 -0700; 3 days ago
Main PID: 1489 (code=exited, status=0/SUCCESS)
Status: "Start Main process"
CGroup: name=systemd:/system/readynasd.service
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
root@READYNAS:~# journalctl -a | grep apache2 | tail -n 20
Jan 24 21:06:00 READYNAS apache2[1903]: [error] [client 192.168.1.126] Connect rddclient failed, referer: http://192.168.1.133/admin/
Jan 24 21:06:00 READYNAS apache2[1903]: [error] [client 192.168.1.126] Premature end of script headers: dbbroker.cgi, referer: http://192.168.1.133/admin/
Jan 24 21:06:00 READYNAS apache2[3124]: [error] [client 192.168.1.126] Connect rddclient failed, referer: http://192.168.1.133/admin/
Jan 24 21:06:00 READYNAS apache2[3124]: [error] [client 192.168.1.126] Premature end of script headers: dbbroker.cgi, referer: http://192.168.1.133/admin/
Jan 24 21:06:05 READYNAS apache2[3002]: [error] [client 192.168.1.126] Connect rddclient failed, referer: http://192.168.1.133/admin/
Jan 24 21:06:05 READYNAS apache2[3002]: [error] [client 192.168.1.126] Premature end of script headers: dbbroker.cgi, referer: http://192.168.1.133/admin/
Jan 24 21:06:09 READYNAS apache2[2201]: [error] [client 192.168.1.126] Connect rddclient failed, referer: http://192.168.1.133/admin/
Jan 24 21:06:09 READYNAS apache2[2201]: [error] [client 192.168.1.126] Premature end of script headers: dbbroker.cgi, referer: http://192.168.1.133/admin/
Jan 24 21:06:10 READYNAS apache2[1904]: [error] [client 192.168.1.126] Connect rddclient failed, referer: http://192.168.1.133/admin/
Jan 24 21:06:10 READYNAS apache2[1904]: [error] [client 192.168.1.126] Premature end of script headers: dbbroker.cgi, referer: http://192.168.1.133/admin/
Jan 24 21:06:15 READYNAS apache2[1928]: [error] [client 192.168.1.126] Connect rddclient failed, referer: http://192.168.1.133/admin/
Jan 24 21:06:15 READYNAS apache2[1928]: [error] [client 192.168.1.126] Premature end of script headers: dbbroker.cgi, referer: http://192.168.1.133/admin/
Jan 24 21:06:27 READYNAS apache2[14246]: [error] [client 192.168.1.126] Connect rddclient failed, referer: http://192.168.1.133/admin/
Jan 24 21:06:27 READYNAS apache2[14246]: [error] [client 192.168.1.126] Premature end of script headers: dbbroker.cgi, referer: http://192.168.1.133/admin/
Jan 24 21:06:27 READYNAS apache2[1905]: [error] [client 192.168.1.126] Connect rddclient failed, referer: http://192.168.1.133/admin/
Jan 24 21:06:27 READYNAS apache2[1905]: [error] [client 192.168.1.126] Premature end of script headers: dbbroker.cgi, referer: http://192.168.1.133/admin/
Jan 24 21:06:41 READYNAS apache2[1903]: [error] [client 192.168.1.126] Connect rddclient failed, referer: http://192.168.1.133/admin/
Jan 24 21:06:41 READYNAS apache2[1903]: [error] [client 192.168.1.126] Premature end of script headers: dbbroker.cgi, referer: http://192.168.1.133/admin/
Jan 24 21:06:46 READYNAS apache2[3124]: [error] [client 192.168.1.126] Connect rddclient failed, referer: http://192.168.1.133/admin/
Jan 24 21:06:46 READYNAS apache2[3124]: [error] [client 192.168.1.126] Premature end of script headers: dbbroker.cgi, referer: http://192.168.1.133/admin/
Nothing for the 4th command
root@READYNAS:~# journalctl -a | grep readynasd | tail -n 20
root@READYNAS:~# btrfs fi show
Label: '0e370a82:data' uuid: a638e4b0-2edb-4b09-9097-c65871d5651a
Total devices 1 FS bytes used 3.02TiB
devid 1 size 8.17TiB used 3.03TiB path /dev/md127
Btrfs v3.17.3
root@READYNAS:~# btrfs fi df /data
Data, single: total=3.02TiB, used=3.01TiB
System, DUP: total=8.00MiB, used=352.00KiB
System, single: total=4.00MiB, used=0.00B
Metadata, DUP: total=6.00GiB, used=4.33GiB
Metadata, single: total=8.00MiB, used=0.00B
Filesystem Size Used Avail Use% Mounted on
rootfs 3.8G 387M 3.2G 11% /
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 3.8G 387M 3.2G 11% /
tmpfs 248M 0 248M 0% /dev/shm
tmpfs 248M 2.7M 245M 2% /run
tmpfs 248M 0 248M 0% /sys/fs/cgroup
tmpfs 248M 0 248M 0% /media
/dev/md127 8.2T 3.1T 5.2T 38% /data
/dev/md127 8.2T 3.1T 5.2T 38% /apps
/dev/md127 8.2T 3.1T 5.2T 38% /home
/dev/md127 8.2T 3.1T 5.2T 38% /run/nfs4/home
tmpfs 4.0K 0 4.0K 0% /data/Music/snapshot
/dev/md127 8.2T 3.1T 5.2T 38% /data/Music/snapshot/c_2015_01_10__00_00_33
root@READYNAS:~#
