jamstrange
Jun 13, 2012Aspirant
Hard drive enclosure recommendations
Because of a failure of one or two of the disks, I just upgraded my old ReadyNAS Duo (RND2150) with two 2TB green drives. I want to get one or two hard drive enclosures to access the old data on the o...
HERBIEO
Jun 16, 2012Aspirant
i have one of these http://www.xigmatek.com/product.php?productid=47 which is really usefull for what you want to do, it supports esata and usb 2.0 and takes 3.5 and 2.5 hard disks, there is a newer version of this which is usb 3.0.
been great had no problems with it, the good thing about these docks is you can just pop the hard disk in the top no opening it up and easy to swap drives about.
this is the usb 3.0 model http://www.xigmatek.com/product.php?productid=114
