Callesoroe's avatar
Callesoroe
Haveged on ReadyNas Ultra ?
I am running LMS (squeezebox) on my readynas ultra. There is a problem with the Random mix. The problem is that it isn't very random.
The problem could be this that I have read about:
http://www.issihosts.com/haveged/
Is it possible to get Haveged to run on a ReadyNas. And if. How ?
If this really is a problem in the kernel software. Will this not be fixed ????
  • StephenB wrote:
    F.L. wrote:
    Is this needed on OS6 6.1.5?
    My RN102 reports values between 100-200 - similar to what fastfwd saw before he did the add-on.
    Strange, now I have low values again.
    And
    watch -n 1 cat /proc/sys/kernel/random/entropy_avail
    gives me low values too.
    Wonder why I had high values before...
    Anyway. I installed haveged using apt and now it seems OK again.
    And
    If nothing is using dev/random or dev/urandom, the entropy pool gradually fills. Presumably, your system wasn't doing much that needed random numbers, so the pool filled to 2000+ bits.
    Every time a new process is launched, the operating system reads from dev/urandom in order to randomize the process's address space layout (to protect from buffer overflow attacks), so when you repeatedly invoked cat once per second with that watch command, the available entropy decreased faster than it could be replenished.
  • fastfwd wrote:
    And
    Thank you fastfwd for the explanation!
ProSupport for Business
