Bergerton
Nov 24, 2014Aspirant
Having a hiccup with my NV+
Hello. Long time user on the NV+, will be needing some help with a hiccup I'm experiencing.
vandermerwe
Nov 25, 2014Master
http://support.wdc.com/product/download ... =3&lang=en
Green drives are not recommended, although they may be on the HCL.
That's pretty old firmware, when last did you do a factory reset, was it before 4.1.7?
If you can ssh in you can do
which will provide info about the OS partition, although it doesn't sound like that is the issue.
If you don't have a backup of data on the nas then now is the time to make one.
df -i
df -h
