Bergerton
Nov 24, 2014Aspirant
Having a hiccup with my NV+
Hello. Long time user on the NV+, will be needing some help with a hiccup I'm experiencing.
Bergerton
Nov 25, 2014Aspirant
Yeah, I had tried upgrading to 4.1.9, but it broke my Time Machine backups, so I rolled back and have stuck with it.
I don't recall having done any factory resets since initial setup.
df -i result:
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/hdc1 128000 12453 115547 10% /
tmpfs 7070 1 7069 1% /USB
/dev/c/c 182812672 499900 182312772 1% /c
df -h result:
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 644M 1.3G 33% /
tmpfs 16k 0 16k 0% /USB
/dev/c/c 5.4T 3.6T 1.8T 67% /c
I will go pick up a hard drive dock this afternoon and start testing drives.
I was of the impression the NAS would have reliable disk error checking built in.
I'm guessing I was mistaken? Or is this a fringe case?
df -i result:
df -h result:
