Bergerton
Nov 24, 2014Aspirant
Having a hiccup with my NV+
Hello. Long time user on the NV+, will be needing some help with a hiccup I'm experiencing.
vandermerwe
Nov 25, 2014Master
If the smart data is perfect then the drives are probably ok, it's always worth checking in situations like this where writes and filesystem checks are failing.
The reason I asked about the last factory default is explained here:
viewtopic.php?f=65&t=56531
